Sometimes we find App.config inadequate in addressing our problems and need to have a generic solution in creating strongly typed configuration files. Depending on the requirements, this can be achieved in multiple ways. In this article, I will illustrate one simple way of creating a type-safe configuration handler which can be easily adapted to more complex scenarios.
<Configurations xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema">
<Entry Property1="Test1" Property2="Test2" />
</Configurations>
public class ConfigNode
private string _property1 = string.Empty;
private string _property2 = string.Empty;
[System.Xml.Serialization.XmlAttribute("Property1")]
public string Property1
get { return _property1; }
set { _property1 = value; }
[System.Xml.Serialization.XmlAttribute("Property2")]
public string Property2
get { return _property2; }
set { _property2 = value; }
public ConfigNode(string property1, string property2)
_property1 = property1;
_property2 = property2;
public ConfigNode()
[System.Xml.Serialization.XmlRoot("Configurations")]
public class ConfigElement
private ConfigNode _node = null;
[System.Xml.Serialization.XmlElement("Entry")]
public ConfigNode Node
get { return _node; }
set { _node = value; }
public ConfigElement(ConfigNode node)
_node = node;
public ConfigElement()
public void SetXmlProperties(Type objType, string fileName, object settings)
XmlSerializer serializer = new XmlSerializer(objType);
XmlTextWriter writer = new XmlTextWriter(fileName, Encoding.UTF8);
writer.Indentation = 4;
writer.Formatting = Formatting.Indented;
serializer.Serialize(writer, settings);
writer.Close();
public object GetXmlProperties(Type objType, string fileName)
XmlTextReader reader = new XmlTextReader(fileName);
object obj = serializer.Deserialize(reader);
return obj;
class Program
public void SetProperties()
ConfigElement element = new ConfigElement(new ConfigNode("Test1", "Test2"));
XMLPropertyHandler handler = new XMLPropertyHandler();
handler.SetXmlProperties(typeof(ConfigElement), "test.xml", element);
public void GetProperties()
ConfigElement element = handler.GetXmlProperties(typeof(ConfigElement), "test.xml") as ConfigElement;
static void
Program p = new Program();
p.SetProperties();
p.GetProperties();
The main benefit of the approach discussed here is that the handler class provides a generic way of accessing attributes driven property files. As long as the entries are defined via attributes, the handler class remains the same. This makes it easy for a generic way of handling multiple configuration files.
